System.TypeInitializationException: The type initializer for 'NationalInstruments.UI.Internal.WaveformPlotElement' threw an exception.
Hi group i have created a setup project that use nationalinstruments.wavform component the setup work properly over 32 bit operating system e.g. (winxp,win7) but throw this exception when it is being installed over a 64 bit operating system.
my development machine is win7-32 bits
looking 4 ur response
(5,983 Views)
ab4abubakar,
When you compile it in the 64 bit system, please make sure that you have selected the correct 64-bit Assembly version. Please refer to this article for further information. Or try to force your application to be built in 32-bit. You can do this by going to the Properties of your project and select Build>>Platform target>>x86.
Carmen C.
(5,966 Views)
Thanks 4 ur kind response
but the problem still presist and the link u refer is un responsive
should i shift my project from vs 2008 to vs 2010
waiting 4 ur response.
(5,947 Views)
