System.DINotFoundException: Unable to load DLL 'nianlys.dll': The specified module could not be found
Hi..
There is an error says as:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
System.DINotFoundException: Unable to load DLL 'nianlys.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at NationalInstruments.Analysis.Internal.k.b(Int32 A_0, Int32 A_1)
at NationalInstruments.Analysis.Internal.k.a(Int32 A_0, Int32 A_1). "
Could anyone please help me?
Thanks.
Suhaini
(3,816 Views)
1. What is the version of Measurement Studio? Please state both version number, and the system you use (standard, proferssional, enterprise?)
2. What is the version of Visual Studio and language you intend to use?
3. Please write down steps to reproduce the problem in detail. For example:
3.1 open Visual Studio.
3.2 Create program from template (which template?)
3.3 so on...
(3,789 Views)
I got the same error.
I have
- measurement studio 8.6 from national instrument suite developper
- Visual studio 2008 and I use Visual Basic
- The problem seems to be related with the decimation or the filtration process.  I can't tell precisely because the problem is only on the publish version installed on machines that never had a "visual basic/measurement studio program" before
(3,678 Views)
