Stopping panning of Scattergraph after reaching the end of plot area
I want to restrict panning of scattergraph after user scrolls to the end of the graph.  Currently even after reaching the end, user can still continue dragging the white area.
Full graph:
User scrolls to white area:
(3,057 Views)
Hi arunkumar.s,
One way to go about this would be to disable panning altogether and instead add a horizontal scrollbar. This scrollbar could control the X Axis for the graph, and restrict the user to only scrolling through the "allowed" range for the graph.
NickelsAndDimes
Product Support Engineer - sbRIO
(3,024 Views)
Hi NickelsAndDimes,
I allow pan only if user zooms the graph.  So, panning is necessary here.  As you suggest, if I want to disable the panning and add scroll bar, I don't see an inbuilt scroll facility in scattergraph.  Do you have a sample code to achieve this?
(3,021 Views)
I don't have any sample code available, but there's a class called "HScrollBar" under "All Windows Forms" that's essentially just a numeric control. You could set this to have a minimum of 0, and a maximum of ([last x value]-[x width displayed]). Your chart can then read from this scrollbar to set its X scale from [HScrollBar.value] to [HScrollBar.value+x width].
NickelsAndDimes
(3,011 Views)
In which event of graph should I set X scale from [HScrollBar.value] to [HScrollBar.value+x width]?  The graph does not have a onscroll event.
(2,988 Views)
You'll want to use the hScrollBar_Scroll or hScrollBar_ValueChanged event to detect when a change is made, and then edit the graph's X range from that method.
NickelsAndDimes
(2,971 Views)
