SpectrumAnalyzer Example Problem
I'm a Measurement Studio's user. (Version 8.0.1)
I'm trying to compile the "SpectrumAnalyzer example" under
"C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\DAQmxWithUI\SpectrumAnalyzer\cs".
However, there occurred error messages. Owing to I'm using VS2005 Chinese Edtion, so I try to translate these error messages.
It's about "Can not find the defintion of "EndReadWaveForm", "BeginReadWaveForm" & "SyncronizeCallbacks" of the AnalogSingleChannelReader class.
Is there any solution for this problem or anything I should check with? Thanks a lot.
(3,149 Views)
Well, I answer myself.
After installing the newer version of DAQmx(ver. 8.3), the problem has been solved.
(3,139 Views)
