Slide Pointer doesn´t appear on zero after using
Hello, I am using Visual Studio 2010 and want to use the Slide Control (Version 9.1.40). My problem is the following, the control appears really on zero as long as I don’t use the slide control. But the control don’t appear to be on zero when I used the control.
It is moving always a bit up when I scroll it down and the focus will be lost. The value property is 0 so it’s just matter of the look. I attached a screenshot to illustrate what I mean. I even tried it with an untouched slide control and the same problem occurs. I hope it’s just a small setting which I don’t find.
Best regards
(5,080 Views)
Hi, I played around and also found under examples something "Styles". I found out that this problem occures when I set the Scaleposition to "left, right" but when I set it to "Top, Bottom" then the Slider shows exactly the expected behavior. Could it be a bug that the Slide control showes a different behavior under left right Scale position?
(5,060 Views)
Ok I reported it as a bug because I found out that this habit doesn´t occure in Version 8.9 and the example for Visual Studio 2008 but in 9.1.. and Visual 2010 I get this problem. Therefore I am using the Version 8.9 in my VS 2010 C# project now with adding the following line to app.config
<startup useLegacyV2RuntimeActivationPolicy="true">
(5,047 Views)
Hi jeschki,
Thanks for signaling the problem. I will escalate it and keep you up to date.
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(5,038 Views)
A short update to say that this problem has been fixed with Measurment Studio 2012 (NI WindowsForm Assembly 12.0.40.318).
Best regards
______________
Florian Abry
(5,019 Views)
