Simple read of Digital i/o on 6008 winth C#
hey all..
can I wiht no use of messurementstudio read simple digital i/o and analog values from the 6008 ?
plz codeexample  (using DAQmx or ?)
best regards Johnny Koch DK
(3,842 Views)
found the examples in C:\Program files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\DAQmx\Digital\Read Values, but no deviece are found with
physicalChannelComboBox.Items.AddRange(
DaqSystem.Local.GetPhysicalChannels(PhysicalChannelTypes.DILine, PhysicalChannelAccess.External));
help...
(3,838 Views)
Hi Johnny,
If you open your MAX(Measurement & Automation Explorer), you will see your USB-6008 under "Devices and Interfaces->NI-DAQmx Devices" as NI USB-6008: "DevX". Where X=1,2,3.....
Let's run the example from:
C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\DAQmx\Digital\Read Values\ReadDigChan\Cs
Because my USB-6008 is "Dev2"--> I changed to "Dev2/port0/line0:7" under Channel Parameters, and I'm now able to read from Digital port0/line:0:7.
Regards
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,820 Views)
