Show Measurment Studio Activex 7.1 Control Properties at run time in VB.Net 2003
- Measurment Studio 6.0 Controls Had  ShowPropertyPages() property when used in Vb.Net 2003 that launches control property at runtime.
- Could't find this property or equivalent for Measurment Studio Activex 7.1.
NOTE:
-In Vb.Net i placed two controls
(AxCWGraph1)
referenced as COM control from Cwui.ocx (Measurment studio 6.0)
and
( NationalInstruments.UI.WindowsForms.WaveformGraph)
referenced as .Net Measurment Studio 7.1 control
Please see attached screen shoot
Best Regards
Mycat
(3,554 Views)
Hi MyKat,
In Measurement Studio 8.0.1 we came out with PropertyEditor control which allows you to edit a control property graphically at runtime. This control allows you to create applications that allow your end users to configure properties for Windows Forms controls at run time. You can edit properties of any .NET type at run time, including collections, and you can edit expandable properties that represent nested properties of another object, such as major divisions of an axis.
Since you are using Measurement Studio 7.1, you won't have this feature. We have added a ton of new features in between 7.1 and 8.5 (current release), so maybe you should consider upgrading.  Check out the What's New in NI Measurement Studio? page.
For now you will need to create your own "property editor" control if you want one with Windows Forms with Measurement Studio 7.1.
Best Regards,
Jonathan N.
(3,528 Views)
