Setting Yaxis maximum and minimum values
Dear All,
 I try to set maximum and minimum values of Xaxis for scatterPlot object but I failed.
It returns an error "it is read only", to set the maximum value use the constructor.
I look inside the help file but there is no example code.
Any help?
Regards
Cengiz EKEN
Test Engineer
(3,530 Views)
In VB2005 you can set the YAxis range as follows: -
NameOfPlot.YAxes.Item(0).Range =New NationalInstruments.UI.Range(minimumvalue,maximumvalue)
StevieB
(3,520 Views)
