RealFft2d
Does anyone have an example code (in VB, C# or even LabVIEW) on how to use the Dsp.Transforms.RealFft2D?
I have shock data; the x values are the time in seconds and the y values are acceleration levels in g and I need to convert that to the frequency domain.
or is there another function I should be using
Curt
(4,005 Views)
Hi Curt,
I found a FFT example in VB for you. The link is listed below.
http://zone.ni.com/devzone/cda/epd/p/id/2166
I hope this helps.
Josh L.
(3,992 Views)
Hi Josh,
Thanks for the reply.
I found a function that worked for me in the NationalInstruments.Analysis.SpectralMeasurements.Measurements class called AutoPowerSpectrum
Curt
(3,921 Views)
