Pulse Width measurement using NI PXI-6602
How to measure the Pulse Width of a high frequency signal using the NI PXI-6602?
(3,990 Views)
Hi Pazhani,
Find the following links helpful to help you in the task of measuring pulse width of a signal using LabVIEW
https://forums.ni.com/t5/NI-DAQmx-Examples/Measure-Pulse-Width-with-DAQmx/td-p/3504080
https://forums.ni.com/t5/Example-Code/DAQmx-Counter-Finite-pulse-width-measurement-with-Event/ta-p/3...
https://www.ni.com/docs/en-US/bundle/ni-daqmx/page/measuring-period-semi-period-pulse-width-and-.htm...
You would typically find more in the example finder present in LaBVIEW / LabWINDOWS CVI under counter IO tasks.
Cheers
Rao
(3,952 Views)
You can also check this link for example program on " NI-DAQmx: Measure Pulse Width Buffered Continous in .NET"
http://www.ni.com/example/30879/en/
or even measurement studio should have its own set of examples for DAQmx if i'm not wrong.
Or you can find examples in the default paths given in the following white paper:
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx-example-locations-for-labview-a...
Cheers
Rao
(3,947 Views)
