Problems with plotting scattergraph
I am plotting with a scattergraph. I am reading data from a database plotting it with PlotXYAppend. However, on my graph, I also need to insert limit lines, which are also read from a database. The channel data (y-axis) is versed my time (x-axis) which continues to change. I need my limit lines to be seperate from channel plot and to remain on the graph as the time changes on the x-axis. I am very new to C# and using Measurement Studio.  I have code...
private void _Timer_Tick(object sender, EventArgs e)
            double xValue = (double)NationalInstruments.DataConverter.Convert(DateTime.Now.TimeOfDay, typeof(double));
            double yValue = 0.0;
            //double lastXValue = 0.0;
            //double lastYValue = 0.0;
            //Plot1
            if (_plot1 != null)
                     foreach (Item item  in _plot1.Items)
                        yValue = _getter.GetChannel(ch.ID).CurrentValue();
                                               foreach (Table table  in _plot1.Tables)
                            _getter.GetTable(table.ID);
                            foreach (TableData ltd in lookup.TableData)
                                  //PLOTTING LIMIT LINES
                                double ltdXValue = ltd.X;
                                double ltdYValue = ltd.Y;
                                scatterPlot1.LineColor = Color.Red;
                                scatterPlot1.PointColor = Color.Pink;
                                scatterPlot1.PointStyle = PointStyle.SolidTriangleRight;
                                scatterPlot1.PlotXY(ltdXValue, ltdYValue);
                        //Plotting DATA
                        this.scatterPlot1.PointStyle = PointStyle.SolidDiamond;
                        this.scatterPlot1.PointColor = Color.Lime;
                        this.scatterPlot1.LineColor = Color.Yellow;
                        scatterPlot1.PlotXYAppend(xValue, yValue);
Also, for my time I am getting a number like 535330 (double xValue = (double)NationalInstruments.DataConverter.Convert(DateTime.Now.TimeOfDay, typeof(double))). How do I get the current timestamp? Thanks in Advance!
(4,635 Views)
One way to accomplish this would be to create a new plot object, and add it to the ScatterGraph's collection of plots.  Also, to get your X Axis to display the time instead of those large double values, you need to create a format string for the X Axis labels.  I have simplified your code a little bit, and these changes can be seen below:
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            // Assign a format string to the axis label
            scatterGraph1.XAxes[0].MajorDivisions.LabelFormat = new FormatString(FormatStringMode.DateTime, "hh:mm:ss");
        private void timer1_Tick(object sender, EventArgs e)
            Double limitVal = 6.5;
            Random rand = new Random();
            // Create new plot
            ScatterPlot limitPlot = new ScatterPlot();
            // Add new plot to Graph collection
            scatterGraph1.Plots.Add(limitPlot);
            limitPlot.LineColor = Color.Red;
            limitPlot.PointColor = Color.Pink;
            limitPlot.PointStyle = PointStyle.SolidTriangleRight;
            limitPlot.PlotXY(DataConverter.Convert<Double>(DateTime.Now.TimeOfDay), limitVal);
            //Plotting DATA
            scatterPlot1.PlotXYAppend(DataConverter.Convert<Double>(DateTime.Now.TimeOfDay), rand.NextDouble()*10);
 Let me know if I've misunderstood what you were asking for, or if I can help you with anything else!
NickB
(4,631 Views)
Thanks NickB,
I'm just in and will test the code, immediately. I'll let you know how it goes! THANKS!
(4,615 Views)
Nick,
I think your suggestion will work, however, I'm still working on it.
Another thing, I have the correct time stamp when the plot is Channel vs. Time, but when I need it to be Channel vs. Channel, my x-axis is still a time stamp, when I need a range of numbers. Please help.
(4,597 Views)
I have not a clue as to edit a recent post...Sorry...
Another question, how do I get my scattergraph to format automatically. For instance, what if my limit lines are at a point of 1 and 50,000 on the y-axis, and my other points are only at 86. And my database has it where it sets the range for the x and y-axes. For the points that are out of my range, how do I get to see the full graph with all the points plotted.
(4,591 Views)
