Portable Application / DLL Question
So right now I have a real simple data logging application for windows 7. I just use:
  • NationalInstruments.Common ( I didnt find much about licensing ).
  • NationalInstruments.DAQmx ( No license should be needed ).
I am developing under Visual Studio 2013 with Measurement Studio installed. I need to fullfill the following specifications:
  1. Programm can be deployed without the Installation Builder from Ni. Just copy the Release folder to the target system.
  2. Programm can be debugged on the target system with a free Visual Studio version without Measurement Studio installed. In this case I would deploy the full solution file.
Right now when I try 1. there will be an error that the DAQmx library isnt found. But I set up the project on the development system that it ships out a local copy of the dll in the release folder.
I know this is a strange question and personaly I wouldn bother but I need to get this done or find out why it cant be done so I would be really thankfull if you could point me maybe to Ni resources abouth this or answer directly.
Greetings...
Message 1 of 1
(2,290 Views)
