Populate data in AnalogWaveform
Hi folks,
I'm very new to programming with NI Measurement Studio....so this maybe a very cheap mistake, but it already took my hours to find
a lot of way how to don't do it 😉
My code (which was produced by Measurement Studio and the DAQmx assistant) looks like this:
                NationalInstruments.AnalogWaveform<double>[] generatedData = new NationalInstruments.AnalogWaveform<double>[daqTaskComponent1.NumberOfChannelsToWrite];
                // TODO: Populate data to write.
                //throw new System.NotImplementedException("You must populate the data to write before writing the data.");
                generatedData[0].Samples[0].Value = 0;
                daqTaskComponent1.WriteAsync(generatedData);
                waveformGraph1.PlotWaveforms(generatedData);
The problem is, I think the init of generatedData is linked to the output channel, but although
I stated 100 Samples to write, the SampleCount (generatedData[0].SampleCount) is NULL.
I just don't know how to add samples to this object.
Thanks in advance for any hint.
Gregor
(4,104 Views)
Hi Gregor,
it might be better to work through the NI-DAQ Examples. They are very well documented and might give you a good overview. Unfortunately, the DAQmx assistant is a bit tricky to handle.
The folder where you can find the examples would be the following (in Windows 7):
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.0\Analog Out\Generate Voltage\GenMultVoltUpdates_IntClk\CS
Please have a look at one of these; if there are still questions, please ask.
Have a great day,
Stefan
Stefan Egeler
Application Engineer
National Instruments Germany
(4,074 Views)
