PlotXYAppend does not function properly
I am using a ScatterPlot object to plot data in a ScatterGraph for a custom application.  When the graph first loads, I load historical data and pass it to the ScatterPlot object using the PlotXY(double[], double[]) method.  Then I add the ScatterPlot to the ScatterGraph.Plots collection.  All of this functionality works fine.
However, as new data becomes available, I add it to the ScatterPlot using the PlotXYAppend(double, double) method.  The new data point is plotted fine.  Unfortunately, the line that connects the old data to the new point is incorrect.  It connects the first point in the series to the new point.  Is this a known issue, or am I doing something wrong?
Thanks.
(3,453 Views)
This does not seem to be a known issue. Can you post some code which produces this behavior or perhaps you can create and attach a simple application demonstrating this behavior?
Mohammed Haseeb|Measurement Studio|National Instruments
(3,429 Views)
