Perimeter Particle Analysis
Hi, this is my first post, I didn't´t need help until now.
I´m having troubles understanding something that should be very simple. So I´m a little embarrassing.
I just need to get the perimeter of particles on an image, I m using VB.net 2005  and MS 8.6 for VB 2005.
I put here what I already accomplish and is working fine using the example provided.
'VB.NET CODE
Dim report As New NationalInstruments.CWIMAQControls.CWIMAQParticleReport
Private Sub DisplayReport(ByVal reportIndex As Short)
If reportIndex < 1 Or reportIndex > CInt(NumParticles.Text) Then
Area.Text = "0"
NumHoles.Text = "0"
COMX.Text = "0"
COMY.Text = "0"
Orientation.Text = "0"
BoundLeft.Text = "0"
BoundTop.Text = "0"
BoundRight.Text = "0"
BoundBottom.Text = "0"
BoundWidth.Text = "0"
BoundHeight.Text = "0"
Exit Sub
End If
Area.Text = CStr(report.Item(reportIndex).Area)
NumHoles.Text = CStr(report.Item(reportIndex).NumberOfHoles)
COMX.Text = CStr(report.Item(reportIndex).CenterOfMass.X)
COMY.Text = CStr(report.Item(reportIndex).CenterOfMass.Y)
Orientation.Text = CStr(report.Item(reportIndex).Orientation)
BoundLeft.Text = CStr(report.Item(reportIndex).BoundingRect.Left)
BoundTop.Text = CStr(report.Item(reportIndex).BoundingRect.Top)
BoundRight.Text = CStr(report.Item(reportIndex).BoundingRect.Width + CDbl(BoundLeft.Text))
BoundBottom.Text = CStr(report.Item(reportIndex).BoundingRect.Height + CDbl(BoundTop.Text))
BoundWidth.Text = CStr(report.Item(reportIndex).BoundingRect.Width)
BoundHeight.Text = CStr(report.Item(reportIndex).BoundingRect.Height)
End Sub
Private Sub ContParticulas_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ContParticulas.Click
' Get the particle reports
CWIMAQVision1.ParticleReport(CWIMAQViewer2.Image, report, , )
' display results
NumParticles.Text = CStr(report.Count)
ReportNum.Value = 1
ReportNum.Enabled = (report.Count > 0)
ReportNum.Maximum = report.Count
ReportNum.Minimum = 1
DisplayReport(1)
End Sub
Private Sub ReportNum_ValueChanged(ByVal eventSender As System.Object, ByVal e As System.EventArgs) Handles ReportNum.ValueChanged
DisplayReport(ReportNum.Value)
End Sub
The thing is that CWIMAQParticleReport not provide perimeter. I find at Ni Vision for Visual Basic reference help that
CWIMAQFullParticleReport does, this one refers to CWIMAQVision.Particle method, but this one is obsolete an refers to CWIMAQVision.ParticleReport and this one expects an CWIMAQParticleReport as return object parameter and not a CWIMAQFullParticleReport object, so I´m not understanding or missing something.
Please I just need an example like provided before that includes the perimeter of a particle.
Thanks in advance.
MCAR.
(3,581 Views)
Somebody please?
(3,537 Views)
