ObjectDisposedException in NationalInstruments.ui.windowsForms.dll.
I am getting ObjectDisposedException in NationalInstruments.ui.windowsForms.dll. It's version in my computer is 8.1.20.256. I tried to access the version 8.0.11.237 got installed by the MStudio800VS2005Patch.exe. I am failed to achieve this since this version is a lower version and not compatible with Measurement studio 8.1 . Can u pls help me to fix this.
(4,376 Views)
Hi Jasi,
I have posted a response to your question here.  In the future please do not post duplicate questions on the discussion forums.
Pat P.
Software Engineer
(4,362 Views)
//I am getting ObjectDisposedException in NationalInstruments.ui.windowsForms.dll. It's version in my computer is 8.1.20.256. I tried to access the version 8.0.11.237 got installed by the MStudio800VS2005Patch.exe. I am failed to achieve this since this version is a lower
//version and not compatible with Measurement studio 8.1 . Can u pls help me to fix this.
Hi Pat,
Thanks for your response. I am using Measurement Studio 8.1 Evaluation Edition 8.1.0.256. Right now i am developing the proof of concepts, in which i am reading out the values from the CAN bus and displaying the responses on the gauge/waveform controls. I am using C#. I am getting the abovesaid exception when i try to close the application window.
Jasmine
(4,334 Views)
Hey Jasmine,
Are you able to run the examples that ship with Measurement Studio?  There should be a simple example located at C:\Program Files\National Instruments\MeasurementStudioVS2005\DotNET\Examples\Application\SimpleGraph.  Does this give the same error or is it only applications that are reading from the CAN bus?  How are you accessing the CAN driver? Through the C interface?
Pat P.
Software Engineer
(4,304 Views)
