Numerics Controls Throw System.NotSupportedException
When Runtime Exceptions are enabled (Debug -> Exceptions...), several Numerics controls throw:
A first chance exception of type 'System.NotSupportedException' occurred in PresentationFramework.dll
Additional information: Cannot convert the value in attribute 'Property' to object of type 'System.Windows.DependencyProperty'.
No usable stacktrace or inner exception.
Microsoft Visual Studio Pro 2013 Update 3
Measurement Studio 2013 - 13.0.45.242
(6,869 Views)
I was able to reproduce the first-chance exception you are seeing. It appears that if you use a TemplateBinding with a converter, and do not specify the target type of the ControlTemplate, then WPF will fail to resolve the property on the first attempt (causing the exception), but will still end up generating the correct binding.
I have created a task to update our control templates to correct this.
~ Paul H
(6,862 Views)
There is a secondary exception being throw after the first one reported. If I remove the TankDouble control from my application, both exceptions no longer appear.
System.Xaml.XamlObjectWriterException occurred
_HResult=-2146233088
_message=Failed to create a 'DependencyProperty' from the text 'IsEnabled'.
HResult=-2146233088
IsTransient=false
Message=Failed to create a 'DependencyProperty' from the text 'IsEnabled'.
Source=System.Xaml
LineNumber=0
LinePosition=0
StackTrace:
at System.Xaml.XamlObjectWriter.Logic_CreateFromValue(ObjectWriterContext ctx, XamlValueConverter`1 typeConverter, Object value, XamlMember property, String targetName, IAddLineInfo lineInfo)
InnerException: System.NotSupportedException
_HResult=-2146233067
_message=Cannot convert the value in attribute 'Property' to object of type 'System.Windows.DependencyProperty'.
HResult=-2146233067
IsTransient=false
Message=Cannot convert the value in attribute 'Property' to object of type 'System.Windows.DependencyProperty'.
Source=PresentationFramework
StackTrace:
at System.Windows.Markup.DependencyPropertyConverter.ResolveProperty(IServiceProvider serviceProvider, String targetName, Object source)
at System.Windows.Markup.DependencyPropertyConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object source)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateObjectWithTypeConverter(ServiceProviderContext serviceContext, XamlValueConverter`1 ts, Object value)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateFromValue(ServiceProviderContext serviceContext, XamlValueConverter`1 ts, Object value, XamlMember property)
at MS.Internal.Xaml.Runtime.PartialTrustTolerantRuntime.CreateFromValue(ServiceProviderContext serviceContext, XamlValueConverter`1 ts, Object value, XamlMember property)
InnerException:
Followed by:
System.NullReferenceException occurred
_HResult=-2147467261
_message=Object reference not set to an instance of an object.
HResult=-2147467261
IsTransient=false
Message=Object reference not set to an instance of an object.
Source=System.Xaml
StackTrace:
at MS.Internal.Xaml.Context.ObjectWriterContext.GetDestinationType()
InnerException:
(6,849 Views)
The XamlObjectWriterException is for the same template-bound property that caused the NotSupportedException exception.
Unfortunately, the NullReferenceException is due to a bug in Microsoft's implementation of IDestinationTypeProvider, which we use when parsing range values. I have created a separate task to see if we can avoid this error when the range value includes the target type.
~ Paul H
(6,833 Views)
Just wanted to let you know these issues have been fixed in the Measurement Studio 2015 release.
~ Paul H
(5,674 Views)
