NationalInstruments.DAQmx.DLL versioning
Hello
anyway I will try any option, so if you can create a runtime4 driver for the 8.6.1 version for me, you are welcome.
Once created, my application should work just placing the NationalInstruments.Common and NationalInstruments.DAQmx
in place, is it correct ?
Thank you
Message 11 of 22
(3,128 Views)
Hi Lorenzo,
I'm double-checking to see if there is any other way of trimming down DAQmx but I am 99% sure that the Runtime4 option is going to be our best bet.
With regards to your second question, I don't suggest trying to copy individual files over to your target computer like you are suggesting since its very easy to forget a certain file. Plus, you need to be careful of how you deploy the NationalInstruments.Common assembly since its versioning is different than versioning of other assemblies. You can read about this in the Measurement Studio .NET Class LIbrary Versioning for Development and Deployment help topic in the NI Measurement Studio Help.
I would suggest that you build and installer and refer to the Measurement Studio .NET Merge Modules help topic which tells you which merge modules you need to have in your installer.  This table will list all the necessary parts you need for distribution.
Best Regards,
Jonathan N.
Message 12 of 22
(3,128 Views)
Hi Lorenzo,
So I looked into the issue and found out that for the upcoming release of DAQmx, the DAQ team will be publicly posting the DAQmx Runtimes and I believe they should have a Runtime5 option which would would be a little more reduced installer than the option I mentioned. Now, I can go ahead and provide you with a Runtime4 DAQmx 8.6 installer, but if at all possible, I would suggest you wait until we release the next version of DAQmx on the web which will have the reduced runtimes.  If this doesn't work for you, let me know.  The next version of DAQmx should be releasing soon.
Best Regards,
Jonathan N.
Message 13 of 22
(3,106 Views)
Hello Jonathan
Thank you for your support, I'll wait for the release
best regards
Message 14 of 22
(3,104 Views)
Hi Lorenzon,
We just uploaded and made public the DAQmx 8.7.1 release.  We have also created the Runtime 3 and Runtime 5 flavors available as well. For you, I would suggest using the Runtime 5 option as that's our smallest installer.
Best Regards,
Jonathan N.
Message 15 of 22
(3,091 Views)
thank you for the links, I'll try them !
best regards
Message 16 of 22
(3,088 Views)
Hello Jonathan
We have tried the new runtime engine, on a base XP installation
We found that there is no improvement, as the installer doesn't start because it can't find the "SupportFiles" folder,
and many packages related to PXI
Please advise the RD to rebuild the runtime 5.
Best Regards
Message 17 of 22
(3,083 Views)
Hi Lorenzo,
I just downloaded that self-extracting EXE onto my test machine and it worked fine. There is a SupportFiles folder present in the extracted files.  Attached is what the folder looks like after self-extracting the files.
Best Regards,
Jonathan N.
Message 18 of 22
(3,078 Views)
Hello Jonathan, you are right
our vmware virtual machine had some problem copying all the files...
now we retried, it is complete, and seems to work !!
Btw, I see an "f3" on the file name of the complete, what is it for ? is it somehow a "beta" release ?
Thank you and best regards
Message 19 of 22
(3,073 Views)
Hi Lorenzo,
Where are you exactly seeing this "f3" text? I don't really understand what you mean by "complete".  This is not a beta release or version and therefore you don't have to worry about anything. I'm glad that everything installed properly for you.
Best Regards,
Jonathan N.
Message 20 of 22
(3,069 Views)
