NI help not available after upgrading .net to Visual Studio 2005
After upgrading my Microsoft .net Visual Studio to Visual Studio 2005, the help for National Instruments is no longer available.
I suppose that the help will show again after re-installing NI, but it takes a long time to do so, and I'd rather maintain the actual status of my equipment, since everithing it's working but the NI help system.
Is there a way to repair that, for the help system to work again?
(3,222 Views)
I'm assuming when you say the help for National Instruments is not available, you are referring to the help for Measurement Studio. If this is not the case, could you clarify which National Instruments product you are referring to?
Measurement Studio 7.x does not currently support VS 2005 Beta 2 so if you try to view the Measurement Studio help in the 2005 viewer, it will not work. You will need to use the Visual Studio 2003 Help viewer or the Help viewer installed with the MSDN to view the help. You can also use this standalone Help2 viewer to view the help.
If you are planning to use the Measurment Studio 7.x class libraries with Visual Studio 2005, please check out this KB for information about issues with Visual Studio 2005 Beta 2.
Message Edited by bilalD on 07-18-2005 08:42 AM
Bilal Durrani
NI
(3,222 Views)
Yes, you were right assuming my problem related to NI Measurement Studio help.
I've just downloaded the application you mentioned and now I'll be able to carry on figuring out about the NI objects and the properties and methods they expose.
Thank you for your quick response!
(3,213 Views)
