NI-DAQmx API reference for Visual Studio 2010?
I have searched the discussion boards high and low and have not found a solution that helps me.
I am using NI-DAQmx 9.5.5 with Visual Studio 2010. The link to the NI-DAQmx .NET Framework 4.0 Reference is broken.
I cannot find any other documentation on the API. I've tried using the examples but they are very simple and lack explanatory comments.
What do I need to do to get the documentation working?
(5,748 Views)
Hi wcwaldsc,
What link are you referring to?  The documentation is available from "Start menu » All Programs » National Instruments » NI-DAQ » Text-Based Code Support » NI-DAQmx .NET Framework 4.0 Help".  Does this work for you?  If not, what behavior are you seeing?
Cheers,
Che T.
(5,739 Views)
