NI 9862 + NI cDAQ-9174 for C#
https://www.ni.com/en-us/shop/model/ni-9862.html
https://www.ni.com/en-us/shop/model/cdaq-9174.html
I was recently given hardware in order to program some joysticks. The joysticks are coming in through a CAN bus and I can see the data/bits in MAX. However, I'm not quite sure where to start on recieving this data. I installed Measurement Studio but I have no idea which classes from the API to actually use to read these values. I would appreciate some direction.
(5,816 Views)
Found a solution. I can write the logic in LabView and export it has a .net interop assembly.
(5,804 Views)
