Missing NI specific assembly reference (ModularInstruments)
I'm considering the use of an NI-Device (NI-5663E) with Measuring Studio. I found a nice example program:
C:\Users\Public\Documents\National Instruments\MStudioVS2010\DotNET\Examples\RfsaWithUI\PowerVsTime-Zero-Span\cs
But there seems to be a missing assembly reference:
As you can see NationalInstruments is known, but ModularInstruments is not.
which is curios because all the software was installed inclusively NI-RFSA Frontpanel / All LabVIEW and MesauringStudio parts.
Does someone has an idea what could cause this or what has to be additional installed to the system?
best regards,
christian
(5,798 Views)
Hi!
Have you installed this?
NI-RFSA .NET Class Libraries 1.2
https://www.ni.com/en/support/downloads/drivers/download.ni-rfsa--net-class-libraries.html
Regards
René
(5,746 Views)
Hi!
...just tested it, it´s not working, i see now what you mean.
Here you can download the dlls
Try throwing it out in the example project and add the dll anew, link to the downloaded rfsa.dll
Greetings
René
(5,743 Views)
