Migrating API driver code in VB6 to activeX code in VB.NET
Hi There,
I recently got a PCI 6533 DIO card to interface with an FPGA board which timestamps TTL pulses coming in. I have some old example code someone sent me that was written in VB6 and makes straight driver calls in order to get the data off the FPGA board. I'm looking to migrate this code to VB.NET and/or C#.NET if possible. The application that I have to write eventually will be distributed among two computers that will have to talk to one another. I have some experience doing that in .NET and it was pretty easy. Doing it in VB6 I'd be starting from scratch to try and figure out how to do it. Not to mention the added benefit that I could also write a web program to allow you to view the experiment over the web as well while it's going on. Anyhow, if I'm totally off the mark and better off sticking in VB6 let me know. Otherwise, what I'm looking for is a good reference to help me migrate the code over. There's really only a couple of driver calls in the old code so it shouldn't be that hard. Unfortunately, the 6533 card doesn't support DAQmx, I went through a couple of DAQmx examples in .NET and they were great, too bad I can't use the object oriented approach to access the 6533 card. So I need to know how to set up the activeX controls in both VB.NET and C#.NET (ie. how/what things am I including, what do I have to declare, all the overhead, etc) and then what equivalent activeX function calls am I making to accomplish the same thing. I've included the old VB code. Like I said, it's only a couple of calls to the driver so if you can show me how to migrate it quickly that would be great. Otherwise, if you could direct me to some info on how to do this that would also be great. I've also been looking for some documentation on how to use the NI activeX controls in .NET. I don't have Measurement Studio, do I need that to get the documentation, or can I find it elsewhere? By documentation I mean information on how to set up the variables and references I needed, and documenation on the different activeX controls I can use and their methods.
Thanks for any help,
Chris
(3,639 Views)
Greetings.
DAQmx 7.5 and higher does support the 653x devices. So you don't need to use the ActiveX controls and deal with interop issues.
For migration to VB.NET from VB 6.0 in general, check out this free book that microsoft is giving away
http://msdn.microsoft.com/vbrun/staythepath/additionalresources/upgradingvb6/
You can see the shipping examples to see how to setup the operations. And ofcourse if you have any questions during your upgrade process, please feel free to use this forum as a resource.
I hope this helps.
Bilal Durrani
NI
(3,630 Views)
