MS 2010 SP1 Deployment by XCopy on Windows 7
I have download yesterday the last version of Measurement Studio 2010 SP1  and build my application that use only the WindowsForms Controls with .NET 4.0.
When I install the application by building an installer by following this steps: http://digital.ni.com/public.nsf/allkb/ED87C183E056CAC386256DF1004E54C6
The installer install something but the application does not start and I gat crash with details:
Problem signature:
  Problem Event Name:                CLR20r3
  Problem Signature 01:                ifind2demoapplication.exe
  Problem Signature 02:                1.0.0.0
  Problem Signature 03:                4ed782e9
  Problem Signature 04:                NationalInstruments.Common
  Problem Signature 05:                9.1.40.159
  Problem Signature 06:                4df66c42
  Problem Signature 07:                4fc
  Problem Signature 08:                20
  Problem Signature 09:                System.IO.FileNotFoundException
  OS Version:      6.1.7601.2.1.0.256.4
  Locale ID:          1031
  Additional Information 1:          ddc4
  Additional Information 2:          ddc4d1020e382785a13f2de23b6f5962
  Additional Information 3:          3204
  Additional Information 4:          3204840e8f3605ab24fc025ae69d696c
I have tried to distribute the application with XCopy but this also failed. Is there a way for XCopy deployment with MS 2010 SP and if yes where I can find the documentation on this?
The problem is that the documentation failed to integrate properly with my VS documentation.
Best Regards,
Nikolai
(4,021 Views)
Hi Nikolai,
maybe this document helps you:
File or Assembly Not Found When Building an Application in Microsoft Visual Studio .NET 2003 Using ActiveX Controls:
http://digital.ni.com/public.nsf/allkb/7695817C3A9050C98625712B005B720C?OpenDocument
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(4,006 Views)
