Looking for tips on dynamically adding/deleting multiple WaveformGraph objects to/from a form.
My app will have from 3 to 32 waveforms which, for compatibility with existing UI, need to be on separate graphs for resizing and/or removal by user. I am thinking about instantiating these on a panel as needed, keeping track of spacing & sizing with an arraylist. Each graph will then carry its own labels, etc. Panel will scroll when needed to display hidden graphs. It would be nice to have a close button on each graph, but looks to me like this has to be separate from the control.
Appreciate any thoughts/experience on this type of presentation.
(4,086 Views)
Hi Pete,
You are correct that there is no way to put a close button on each graph.
One way I was able to do this was to have an ArrayList of waveformGraphs. In order to create a new control programatically, I copied the Windows Form Designer Generated code and removed the "this." before each of the calls and moved it to a button call. I then added the waveformGraph object to the array list and changed the position based on how many graphs I had inserted.
Good luck!
Allen P.
(4,086 Views)
Allen,
So you created a new waveformGraph object (would you call it a wrapper?) based upon the machine-generated code created by the Form Designer. Could you post some example code to illustrate its' extended use as you describe it?
Thanks.
Pete
(4,086 Views)
Here is the example I have written in C#.
(4,086 Views)
