Limit Line
What is the best way to implement a limit line with different values?
For instance using a WaveformGraph with a Y scale from 50 to -10 and an X scale from 0 to 500. I need a limit line displayed in six different points going from 40, 0 , 0, 0 ,0, 40 in a linear scale.  The linear scale points would be spread equally across the X scale. 40 would be on 0 on the X Scale, 0 on 100, 0 on 200 and so on. Something like the attached jpg.
(5,719 Views)
Have you considered plotting this limit line as another plot on the WaveformGraph? The code might look something like this:
int range = 500;
int numPoints = 500;
double increment = range / numPoints;
double startingPoint = 0.0;
double[] limitLinePoints = new double[numPoints];
double slope = 40.0 / 100.0;
for (int i = 0; i < 100; i++)
limitLinePoints[i] = 40 - (i * slope);
for (int i = 100; i < 400; i++)
limitLinePoints[i] = 0;
int j = 0;
for (int i = 400; i < 500; i++, j++)
limitLinePoints[i] = j * slope;
waveformPlot1.PlotY(limitLinePoints);
(5,698 Views)
Thank You,
That is exately what I needed
(5,682 Views)
