Licensing method for MStudio 2009
In veresion 8.6, I was aware that I'm running a trial version since it asked for serial number during installation. In 2009, the prouduct is installed and there is no clear method to activate it. I fear developing using it and getting stuck if trial is expired as there is no sign to point if I'm on trial or not.
Hope someone could assisst me.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,530 Views)
Hi Waleed,
If you currently have a trial version installed, then anytime you drop a MStudio control on your form, or attempt to compile a project with an unlicensed form element, it will inform you that you are using evaluation mode. More details on the exact behavior can be seen here.
Raj
(3,504 Views)
Hi Raj,
That's the problem. I get no nagging screen and there is no indication that I'm unlicensed or pointing to trial. I guess I'll try to deploy an application and see it on client machine.
Assistant Lecturer
(3,488 Views)
