04-15-2013 03:38 PM
I am using VS2012 and Measurement Studio 2013. Our software depends on both NIDAQmx and VISA. Therefore I need to include the mergemodules for nidaq and visa. Since we now are advised to use WIX, I was looking at the example application. It seems to work fine, however I cannot find an example for NIDAQ/VISA. I can select only the following modules:
< FeatureGroupRefId="AnalysisEnterprise_MergeModules"/>
<!--<FeatureGroupRef Id="AnalysisProfessional_MergeModules"/>-->
<!--<FeatureGroupRef Id="AnalysisStandard_MergeModules"/>-->
<FeatureGroupRefId="MStudioCommon_MergeModules"/>
<!--<FeatureGroupRef Id="DataSocket_MergeModules"/>-->
<!--<FeatureGroupRef Id="NetworkVariable_MergeModules"/>-->
<!--<FeatureGroupRef Id="TDMS_MergeModules"/>-->
<FeatureGroupRefId="UIShared_MergeModules"/>
<!--<FeatureGroupRef Id="UIWebForms_MergeModules"/>-->
<FeatureGroupRefId="UIWinForms_MergeModules"/>
<!--<FeatureGroupRef Id="WPF_MergeModules"/>-->
But no NIDAQ/VISA, can somebody help me out to add mergemodules for NIDAQmx and VISA as well?
Erik
04-18-2013 05:13 AM
Hello rera,
I didn't really find any example related to DAQmx or VISA.
I must admit that I'm personally not really so familiar with WiX, but I'll try my best to help you.
One thing I think is quite important to note is the difference between the MergeModules inherent to Measurement Studio itself (http://digital.ni.com/public.nsf/allkb/42A33C58738B5CBC8625790D0006BA56?OpenDocument) and the Device Drivers you're using (like DAQmx and NI VISA).
As far as I know this should be similar to adding any other drivers to a certain installer package.
There's also some more information about how these Device Drivers can be located on http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/netmergemodules/
PS: Which example are you specifically refering to?
04-18-2013 05:28 AM
Hi Thierry,
Thanks for your reply, I will start reading these links. I am referring to the example as shown in:
C:\Users\Public\Documents\National Instruments\MStudioVS2012\DotNET\Examples\Application\Deployment\WiX
Erik
04-22-2013 08:21 AM - edited 04-22-2013 08:33 AM
Can someone post a working example of how to deploy DAQmx in WiX? The supplied link does not contain any example regarding DAQmx. I tried develping a Wix deploymen file but I don't have enough information to get it working. Thanks
