Is it possible to reset a counter?
I have two options as I see it for my application.  I need to either reset the counter value at some point or figure out how many bits the counters on a 9401 are and then have some calculation to calculate the correct number of counts even when the timer rolls over.
Is there a way to reset the counter?
How many bits are the counters on a 9401?
Thanks.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(4,139 Views)
Hello Michael,
A common misconception with C Series modules such as the 9401 is that there is a counter on board.  This is actually not the case.  The NI-9401 is a digital module which can access the counter(s) in the chassis in which the module is placed.  Assuming you have placed your NI-9401 in a cDAQ-9172 chassis, you can access the counters with this module by placing it in slot 5 or 6.
The counters on board the cDAQ chassis are 32-bit.  This information, and how to perform various counter tasks is contained within the User Guide & Specifications for the cDAQ-9172.
You cannot reset an event counter in the middle of a task.  The only option to reset it is to stop the task and to start the task again.  On the other hand if you are using a quadrature encoder and have an A, B and Z signals (typical with quadrature encoders), the counter will reset with the Z or zeroing signal.
Hope this helps,
Jennifer O.
(4,126 Views)
So in the event that the counter value I measure this second is less than the value read during the last second
(counter overflowed), I should say that the number of pulses in that second was ThisCount + 4294967296 - LastCount?
Thanks!
(4,122 Views)
Hi Michael,
You are absolutely correct.  The counter will go from 0 to 2^32-1 and then back to 0.  Right at roll-over, the count will increment by one from 2^32-1 to 0.  So following your reasoning the difference between old count (2^32-1) and new count (0) should be one.
Testing this you get 0-(2^32-1)+2^32=1
Also, there is a property node in DAQmx that will tell you if the count has rolled over (you can use this as an alternative to comparing your two counts).  The channel property is: "Counter Input:General Properties:More:Terminal Count Reached".  If the counter has rolled over this will return true, and it will automatically reset to false after you read this property.
Jennifer O.
(4,115 Views)
Thanks!
(4,108 Views)
