Inverse DFT
I have working on a vb.net application . I have earlier use NI for polyval function in my application. I need to use a inverse DFT method. I have written a method in vb.net which calculates  inverse dft of 2d array. The method produces acceptable results but the problem is it is taking too much time. The input is an 1200 * 1200 array.Is there any method available for  inverse DFT ?
Arnab
(4,593 Views)
Why don't you use FFt instead of DFT?  From what i understand  Fast Fourier is a faster method of Discrete Fourier.   This is available in the digital signal processing ocx (cwanalysis.ocx i think).
Hope this Helps,
B
(4,546 Views)
 FFT can ONLY be used on a series that is a power of 2.Thats why i need to use DFT not fft
(4,537 Views)
Please follow this link
http://zone.ni.com/reference/en-XX/help/371361E-01/lvanlsconcepts/fft_fundamentals/
i pulled the following paragraph from this page...
When the size of the input sequence is a power of two, N = 2m, you can implement the computation of the DFT with approximately Nlog2
(N) operations, which makes the calculation of the DFT much faster. DSP literature refers to the algorithms for faster DFT calculation as fast Fourier transforms (FFTs). Common input sequence sizes that are a power of two include 512, 1,024, and 2,048.
When the size of the input sequence is not a power of two but is factorable as the product of small prime numbers, the FFT-based VIs use a mixed radix Cooley-Tukey algorithm to efficiently compute the DFT of the input sequence.
hope this helps
B
(4,526 Views)
