Instrument driver wizard missing
I have a professional development license for Measurement Studio 2013 and am using Visual Studio 2012 Professional edition.
- Unfortunately, I can not see the instrument driver wizard (IVI driver). Can someone please help me to know if the above 2 programs are not compatible with each other. Before buying, I went throught MS2013 webpage and that gave me an impression that there sould be no issues.
- Secondly, I also read that creating wrapper around existing C driver is possible using Instrument driver wizard, but is it also possible to create an all new IVI-Driver?
Thank you.
Regards
Ricky
(6,451 Views)
First:for Measurement Studio 2013 Compatibility see: http://www.ni.com/pdf/manuals/373225c.pdf
Secondly: Yes, you can do both 🙂
Fabian
(6,421 Views)
Thanks Fabian,
I read part of manual that says how to create a new instrument driver using Wizard by selecting
Start-->New Project-->Visual C Sharp--> Measurement Studio-->Instrument Driver
My question is why can't I see Instrument driver under Measurement Studio on my PC?
I only see
NI DAQ Windows Application
NI Windows Forms Application
NI WPF Application
NI Class Library
Regards
Ricky
(6,415 Views)
Am I the only one here with this problem?
May be I am missig some packet which I should install in order to see Instrument Driverr Wizard under .NET project. Or the set of template is to be downloaded seprately from internet?
Sorry, if I am asking too much, but will really request someone from NI or their product user to reply.
Regards
Ricky
(6,389 Views)
I wanted to resurrect this old post and chime in.
With Visual Studio 2010, you can invoke the Instrument Driver Wizard by doing this:
* Use the Add New Item then in Visual C# Items, select the .NET Instrument Driver. A wizard comes up asking you where the fp file is located.
(2,907 Views)
