Instrument Drivers
I have written many VB6 applications to control instrumentation. I just got Measurement Studio 2012 to run on Visual Studio 2010.  I would love to use the available interment drivers available from NI. I have no problem importing the driver into the code but every time I try and call it I get an error of
‘is not declared’
For example using the HP 33120A from http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E96B8659CE034080020E748...
  1. I install the driver then restart the computer.
  2. In Visual Studio 2010 (VB.NET) I select Add – New Item
  3. Select NI Instrument Driver
  4. Browse to the driver. In this case C:\Program Files\IVI Foundation\IVI\Drivers\hp33120a\hp33120a.fp
  5. Click Next
  6. Click Finish
  7. I open a form then add a button and text box.
  8. In the Button Click event I try and add a call to the Instrument driver.
  9. I get ‘ ConfigureAMEnabled is not declared’
So what am I missing?
What would be very helpful is a Visual Studio 2010 (VB.NET) software example using Measurement Studio 2012 and any interment driver.
Thank You for the help
(5,090 Views)
Hello PMEL_TMDE,
Looks like you may not be using your functions in quite the right way.  Please see the white paper here: http://www.ni.com/white-paper/4562/en#toc2 and use the example under the "Calling an instrument driver wrapper class" heading.  Please let me know if that helps!
Patrick W.
(5,074 Views)
