Insert relative time scale in Visual C# 08
I am writing an application using Visual Studio 08 with measurement studio.
I want to use relative time scale on my X axis
I have tried using
graph.XAxes[0].MajorDivisions.LabelFormat = new NationalInstruments.UI.FormatString(NationalInstruments.UI.FormatStringMode.DateTime, "%<%H:%M:%S>t");
Doesnt work.
Can someone help me with this?
(5,511 Views)
Hi Pankil,
It looks like you are close, but try using this formatting string "h:mm:ss tt":
graph.XAxes[0].MajorDivisions.LabelFormat = new NationalInstruments.UI.FormatString(NationalInstruments.UI.FormatStringMode.DateTime, "h:mm:ss tt");
 This line worked in an example program I modified, but let me know if you are still havingproblems in your code.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(5,495 Views)
Nope didnt help
Ive attached a pic of what I get with this change.
(5,493 Views)
oops..! here is the image.
(5,492 Views)
Hi Pankil,
It looks like the time stamps are showing up, the problem is just related to a scaling issue.  To fix this, make sure you are properly converting your time axis to the proper range using xAxis.Range.  If you are having trouble finding the correct values, please let me know how many data points you are plotting and what range you are using.
Al B.
CTA/CLD
(5,464 Views)
I am using 5400 data points(90 min run)
I use (DateTime.Now - DateTimeStart).TotalSeconds for xaxis.
(5,460 Views)
Accepted by topic author pankil
Hello Al B,
I did figure out solution for the issue
Using %H:mm:s or H:mm:s both work.
Could you elaborate what difference should '%' normally make?
(5,438 Views)
