I'm getting an exception in my application. It occurs when drawing resumes after removing all annotations from my ScatterGraph. Any idea what could be causing this and what I can do to fix it?
Here is the exception:
Index was out of range. Must be non-negative and less than the size of the collection.
at System.Collections.ArrayList.get_Item(Int32 index)
at NationalInstruments.Restricted.ControlElementCollection.get_Item(Int32 index)
at NationalInstruments.UI.Internal.cg.a(ComponentDrawArgsInternal A_0)
at NationalInstruments.UI.Internal.au.b(ComponentDrawArgsInternal A_0)
at NationalInstruments.UI.Internal.r.b(ComponentDrawArgsInternal A_0)
at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)
at NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)
at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1)
at NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)
at NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)
at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
at System.Windows.Forms.Control.WmPaint(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
Thanks.
