How to synchronize 2 Counter DAQmx tasks in C#
I create 2 Counter tasks to measure the same square wave signal in c#.
Task 1 will measure the signal's semi-peroid, sample size 20 and start at rising edge.
Task 2 will measure the signal's peroid, sample size 10 and start at rising edge.
I want the 2 tasks start at the same rising edge.
If that, the each peroid result of task2 will equal to the sum of each 2 semi-peroid results of task1.
So, how to set the 2 tasks start at the same rising edge in c#?
Daniel
(3,751 Views)
If you know how to read LabVIEW code or know someone who does, https://decibel.ni.com/content/docs/DOC-5706, may be helpful.
This question may be better asked in the Multifunction DAQ forum. This forum is about Measurement Studio which you are not using.
(3,744 Views)
