How to move the Y-axis independently of other Y-axes
I am using scatter graph, having multiple plots. The scatter graph is shown with multiple Y-axes with a common X axis. Desired Y-axis can be  selected by the user (as shown in the fig-1).
What I need to achieve is, the user can move (up or down) the selected Y-axis of the graph independent of the other Y-axes present in the graph as shown in fig-2 (down) and fig-3 (up).
I have depicted the above mentioned scenario in attached sample graph. The scatter graph contains 2 Y-axis for graph1 and graph2. Currently the Y-axis of graph-2 is selected.
fig-1 shows the actual graph
fig-2 shows that Y-axis of graph2 has been moved downward 1unit
fig-3 shows that Y-axis of graph2 has been moved upward 1unit.
I think it can be achieved through panning, but panning moves all the graphs.
Kindly guide through some sample code.
Thankyou.
(5,910 Views)
If each plot is assigned to its own Y-axis, changing the range of one axis should not affect the other. Are you sure that each plot has been assigned a unique axis as shown here?
How is the desired y-xais selected by the user?
How are you moving the axis up and down?
Is there a reason why you can not display both Y Axes?
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
(5,892 Views)
Actually I dont want to change the range. I just want to move the selected graph upwards or downwards, without disturbing the other graph. As I have demonstrated in the attachment.
As I have mentioned earlier the required functionality is just like panning, but the problem is that by doing so both the graphs move.
Thankyou.
(5,885 Views)
It does not appear to be possible to move the plots individually. The panning properties can only be set for the ScatterGraph as a whole. Can you provide more details on why you need to move the graphs individually?
Anjelica W.
(5,867 Views)
