How to measure frequency on PFI0 (DAQPad-6015)
Dear All,
I am trying to measure the frequency (or the period) of a digital input signal which is connected to the PFI0 input on a DAQPad-6015. I tried to modify one of the supplied examples (C:\Program Files\...\MeasDigFrequency_LowFreq1Ctr.sln) in order to use the PFI0 input.
I added the following code to the measureFrequencyButton_Click procedure:
DaqSystem.Local.ConnectTerminals("/Dev1/PFI0","/Dev1/ctr0Source")
after the Try statement. When running the program I get the error message:
Specified route cannot be satisfied, because it requires resources that are currently in use by anther route.
Property: NationalInstruments.DAQmx.CIChannel.CounterTimerbaseSource
Property: NationalInstruments.DAQmx.CIChannel.CounterTimerbaseActiveEdge
Source Device: Dev1
Source Terminal: MasterTimebase
Task Name: CITask
Status Code: -89137
My questions:
1. Is this the right approach or should I use another procedure?
2. Is that the right place (procedure measureFrequencyButton_Click, before creating myTask) to make a connection of DAQ terminals?
Any help is appreciated.
Detlef S.
(3,734 Views)
Sorry, I forgot:
I am using Visual Basic .NET 2003 and NI Measurement Studio 7.1 as development system.
Detlef S.
(3,730 Views)
Hi Detlef
Im not sure but have a look at this page, maybe it will help you:
http://digital.ni.com/public.nsf/websearch/CF592CB42924F9B986256F320053C5C7?OpenDocument
Manuel
(3,706 Views)
Hi Manuel,
thank you. Yes, I have seen that link and that is the reason why I wrote the code
instead of
DaqSystem.Local.ConnectTerminals("/Dev1/PFI0","/Dev1/ctr0").
Maybe I should use the "internal name" for PFI0 also, but I did not find any information about that one (neither online at the NI internet pages, nor in any help file installed on my PC together with NIMS).
Detlef
(3,702 Views)
For those who are interested in the solution of my application (see above):
I added the following line after the myTask.CIChannels.CreateFrequencyChannel statement:
mytask.CIChannels.Item(0).FrequencyTerminal = "/Dev1/PFI0"
and now I am able to run the demo program measuring the frequency of the PFI0 input signal.
The DaqSystem.Local.ConnectTerminals statement is not necessary.
Detlef
(3,675 Views)
