How to bind plots on WPF graph
Is there a way to bind plots (plot collection) to a graph.
I'm using a graph with multiple plots. I bind the datasource  with an observablecollection for the data values => the default plots are shown, perfect.
but now I want to manage these plots (color, axis etc..). For that I have to use plots. I can define manually plots in XAML.
but I want to add or remove plots at runtime. The datasource is perfect for data values but I have not found the same for plots. In the MVVM concept, is there a way to bind plots with a collection.
Thanks for any help.
O .Daniere
(8,253 Views)
There is no equivalent to DataSource for plots. There is a DefaultPlotRenderers collection for customizing the default appearance of plots, but nothing for configuring other properties like associated axes.
There is a primitve type available that can be used to synchronize a model collection with e.g. the Plots collection on a graph:
    var plots = new ObservableCollection<Plot>( ... );
    var synchronizer = new NationalInstruments.Controls.Primitives.CollectionViewSynchronizer( );
    synchronizer.SourceCollection = CollectionViewSource.GetDefaultView( plots );
    synchronizer.TargetCollection = graph.Plots;
You could use this in code, or create an attached "GraphExtensions.PlotsSource" dependency property that performs the same action when the property value changes.
~ Paul H
(8,236 Views)
Thanks for your response Paul.
I have another question regarding the PlotRenderer binding :
Using XAML I can bind the plot color to a class property like this :
<ni:Graph x:Name="MyGraph">
   <ni:Graph.Plots>
      <ni:Plot Label="Plot 1">
         <ni:LinePlotRenderer Stroke="{Binding PlotLineColor}" />
      </ni:Plot>
   </ni:Graph.Plots>
</ni:Graph>
With this code behind in VB.NET 2012 (MyGraphVM contains the PlotLineColor property):
        MyGraph.Plots(0).DataContext = MyGraphVM
And it works.
But, I can't do the same binding by code (for example using Plot.setBinding()).
Do you have an example?
What is the best way to bind plot's properties (color, shape, etc)?
O. Daniere.
(8,194 Views)
You can use the BindingOperations.SetBinding method to set a binding on a plot renderer:
    var renderer = plot.Renderer;
    var binding = new Binding( "PlotLineColor" ) { Source = MyGraphVM };
    BindingOperations.SetBinding( renderer, LinePlotRenderer.StrokeProperty, binding );
~ Paul H
(8,171 Views)
Thanks Paul, it works perfectly.
O. Daniere
(8,146 Views)
By the way, I have created the "GraphExtensions.PlotsSource" example I mentioned earlier in an answer to another question.
~ Paul H
(8,069 Views)
