I have a Windows Application using C# language. The application displays a bar graph whose values on the y-axis varies from 0 to 50.
Due to limited UI space, it becomes difficult at times to read values like 1, 2 etc.
Therefore, I need to add a feature to the graph such that if the user brings the mouse pointer over a particular bar, then a window should open with the enlarged image of that bar.
Can anyone please provide a suggestion on how to achieve the same? Even a slight variation in the feature like if someone has another idea of making the graph easily readable, is fine. All the suggestions are welcome!
