How many ways does VB.NET use VISA?
I know there are two ways:
1, using visa32.dll
2, using NationalInstruments.VisaNS
Is there any other way? What are their shortcomings and advantages?
(3,143 Views)
Hi xiao,
As far as I know, those are the only two ways to use VISA with VB.NET. VisaNS is the legacy .NET API for VISA. If you are developing a new application, then I would strongly recommend NI-VISA.NET instead of VisaNS. I've linked some documentation below that goes more into detail about this:
National Instruments VISA .NET Library
Applications Engineering
(3,117 Views)
thanks
So there are three ways .NET uses VISA:
1,Call visa32.dll directly
2,VisaNS
3,ivi.visa
You think is the best is ivi.visa.Can I understand like this?
(3,114 Views)
Hi xiao,
If you have an existent IVI driver that uses VISA, then I'd recommend using that since it may be easier for you to follow. However directly calling the VISA dll directly will give you a bit more low level control in your application. At the end of the day it comes down to preference.
(3,109 Views)
Can you send me an example about calling visa 32. DLL? thank you!
z-jzhao@163.com
(2,588 Views)
