How do I control where merge module installs DAQmx.dll ?
I have a .NET app developed under VS 2005 that uses DAQmx 8.7.1
My VS setup (Deployment Project) has a detected dependency to merge modules  mstudiocommon.2005.msm and mstudiodaqmx.2005.msm, as it should
When a user runs the app's .msi, the user specifies the "parent" installation folder like:
C:\Program Files\MyApp\
And the app's executables get installed into:
C:\Program Files\MyApp\bin
And its database gets installed into:
C:\Program Files\MyApp\db
And various other folders are created under:
C:\Program Files\MyApp\Projects
(this folder structure is very deeply ingrained within the app, so changing it isn't an option).
The problem is that NationalInstruments.DAQmx.dll gets installed in C:\Program Files\MyApp  (ie, the "parent" folder, and thus my app can't find it at runtime).
How do I make it install DAQmx.dll into C:\Program Files\MyApp\bin   ???
DT
(3,799 Views)
I discovered that the VS Deployment project allows me to over-ride the Module Retargetable Folder property of the MergeModuleProperties (for mstudiodaqmx.2005.msm).
Sounds like that might work, assuming it does what I think it does!
David
(3,797 Views)
(yes, it works)
(3,796 Views)
