How do I access PXI-4132 serial number?
I've created an NI Instrument Driver class using the nidcpower.fp file and am able to successfully communicate with the PXI-4132. As part of our calibration procedure, I need to be able to extract the serial number of that card and I do not see any means of doing that in the nidcpower() class. Please advise on how to obtain this serial number programmatically. Thanks.
(3,274 Views)
Hi Chris,
I wasn’t able to find any way within the DCpower driver, however using the DAQmx driver, serial number is a property under the device class for the DAQmx namespace. The DCpower driver is built similarly to the DAQmx driver and this properly should work for both.
Matt
(3,257 Views)
