How can I get the DAQmx/common library versions at run time?
I'd like to show the version of the DAQmx.dll and common.dll in the system, much like you can show the .NET version with
System.Environment.Version
How do I do this?
(3,171 Views)
NationalInstruments.DAQmx.DaqSystem.Local.DriverMajorVersion.ToString + "." + _ NationalInstruments.DAQmx.DaqSystem.Local.DriverMinorVersion.ToString + "." + _ NationalInstruments.DAQmx.DaqSystem.Local.DriverUpdateVersion.ToString
(3,168 Views)
