HistoryCount and HistoryCapacity
I've been working on my Wavformgraph and I'm getting close to having it where I want it (although I still can't seem to be able to plot against time on the XAxis).  I understand that HistoryCount is the number of samples that are in the history and that HistoryCapacity is the maximum allowable number of data points allowed in the history.  I did a test last night where I was logging and appending data at the following settings (see screen shot).  In my program, I was appending the data to the graph every 1ms.  So my question, to verify with experts, is that according to the screenshot here, I am taking samples every 1ms which gets stored in the HistoryCount, and then according to my timer in my code, I am appending that to the Wavform plot every 1 ms?  Is this correct?  If I set the timer that appends the data in the program to 100 ms, does that affect the number of data points that get appended to the plot?
Also, I set up a temporary textbox where HistoryCount.value is getting written to on every append.  It eventually maxed out at 100000, even with my HistoryCapacity set as high as I have it.  Can someone help me to better understand what's going on here.  If my HistoryCapacity is set this high (see screenshot), shouldn't HistoryCount at least reach that value?  I want to record data points every 1ms (1 kHz).  I don't really care so much as to how often the buffer of data gets appended to the plot on the graph.  Thank you for any clarification.
(4,537 Views)
Hi;
Have you seen this?
http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/4fc667f5/
According to the remarks History Capacity is not considered when plotting data.
(4,504 Views)
