Hardware Timed Interrupt
Where can I find sample code for a CTR/TMR channel interrupt so I can create a hardware timed interrupt?
ex. Clock frequency = 1 MHz.  Loop period = 100 ms.
1. Start counting.
2. Trigger interrupt when counter = 10000.
3. Reset counter.
4. Execute interrupt code.
5. Repeat steps 2-5.
Thanks!
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 1 of 39
(7,143 Views)
Hi Michael.
I wasn't able to find a direct example to your request but the following should be a good reference
  COunter Operations with Measurement Studio DAQ ActiveX Controls
  Hardware Reset of a TIO (NI 660x) Counter in Measurement Studio
  Count Digital Events with Option to ResetCounter
Keep in mind that some of the above makes references using the T-DAQ driver, and the last example uses LabVIEW with DAQmx, so you would need to reference the vi's to the functions in the DAQmx C Reference Help.
Glenn
Message 2 of 39
(7,123 Views)
I found an example.  Unfortunately, I need to be installing support for .NET framework 1, 2, and 3.5 in order to get all of the examples.  I would rather have all the examples install with .NET framework 3.5 since that is the one I use...
Message 3 of 39
(7,085 Views)
Can you point to the example you are referencing?
Glenn
Message 4 of 39
(7,067 Views)
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0\Counter\Count Digital Events\CountDigEventsBuffContinuous_ExtClk
You specify the number of counts before it calls the callback function.  It is not a accurate as I've seen on microcontrollers, but it may be OK.  It seems to get more accurate the faster I run the clock, but I might have overrun a variable somewhere because when I try to run the clock at 1,000,000 (I believe) on a PCI 6713 (24 bit counters) and count 100,000 counts it gives me an error stating that I need to divide the signal...  I wish I could use the 20 MHzTimeBase rather than having to use another counter to provide the clock.  I'll post the exact error tomorrow.
Message 5 of 39
(7,064 Views)
The following attachements show the code to configure the tasks to generate a clock signal, count pulses, and toggle a digital channel in order to click the frequency of the interrupt as well as an error that I get when I try to run at 1 MHz or higher using a PCI-6713.  If I need a 10 Hz interrupt using a 1 MHz clock, I have to count 100 kPulses.  It does not like this for some reason.
I'm running a test right now to count the interrupts over a known period of time to determine the error in the system.  The frequency of the interrupt bounces between 9.992 and probably 10.008 (actually half of that due to the fact that each interrupt toggles the digital channel so the frequency is cut in half).  I can handle small errors.  Our tests can be anywhere from 20 minutes to 4 days.  I just need to determine how many extra seconds I end up running if the frequency is slightly less than 10 Hz.
Thoughts on the whole idea?
Message 6 of 39
(7,053 Views)
I ran it for around 2.5 hours and these are my results:
Incrementing a counter each time the interrupt is called:
Start time: 11:09:26
End time: 13:49:58
Elapsed seconds: 9512
Counter value / 10 = 9511.9
I will run 16+ hours next Monday and see what I get, but I can live with these results!
Message 7 of 39
(7,048 Views)
Why would I get that error if I disconnect the clock from the input pin?  I'm trying to put some checks into the code just in case the loop stops firing, but when I disconnect the wire that jumps from the counter output to the counter input I immediately get an error.  It is the same error I posted above.
Thanks.
Message 8 of 39
(6,991 Views)
Hi Michael,
From your above post it sounds like you are using one of the counters as your clock source. By disconnecting that jumper the line may be reading noise that could be misinterpreting it as rising clock edges thus resulting the aforementioned error.
Glenn
Message 9 of 39
(6,973 Views)
I just figured out that I missed the ability to use the internal clock.  I've changed that now so I don't have to use two counter channels.
Message 10 of 39
(6,971 Views)
