Get port and line in difference ways by using Task.DIChannels.CreateChannel
I know I can use this way like  (for example)
"/cardName/port2/line3"    or
"/cardName/port2/line1:5" or
"/cardName/port2:port3"
But if I want to get the bits     4567 from port 2 and bits 012 from port 3?
Something like "/cardName/port2/line4:7/port3/line4:7"??
(3,639 Views)
Hi there,
I think /cardName/port2/line4:7/port3/line0:2 shoud do the trick.
It is also an option to create a task with MAX and then use call it from your code, here is a reference.
(3,589 Views)
Thaks for your answer I try this like
You know what am I doing wrong?
 task = new NationalInstruments.DAQmx.Task();
            task.DIChannels.CreateChannel($"/CardName/port6/line0:7/port7/line0:2", "ch1", ChannelLineGrouping.OneChannelForAllLines);
            readerFirst = new DigitalSingleChannelReader(task.Stream);
            var xxxx = readerFirst.ReadSingleSampleMultiLine();
NationalInstruments.DAQmx.DaqException: 'Syntax for a range of objects in the input string is invalid.
For ranges of objects, specify a number immediately before and after every colon (":") in the input string. Or, if a name is specified after the colon, it must be identical to the name specified immediately before the colon. Colons are not allowed within the names of the individual objects.
(3,582 Views)
Hi there,
I think this error proved us wrong, this is an invalid way to declare the range of lines.
Have you tried creating a second channel, removing the "port7" section of this line code and adding it in another line?
(3,577 Views)
Yes,  that what I did .
(3,575 Views)
Glad that worked! Then you could mark this one as resolved now!
(3,572 Views)
