Error installing NI Developer Suite (-32)
We are attempting to upgrade from Visual Studio 6 to Visual Studio .Net 2005 for our main software. I now have the compile down to only two errors (from NI files) and figured it was time to try to install the newer NI software now for compatability.
I have some DVDs for NI Developer Suite which I tried to install. I select CVI, device drivers over the basic defaults and when I start to install it (asks for another DVD), it immediately comes up with an error:
Error: A file, directory, or other piece of data could not be found. (Error code -32)
Any ideas?
(3,884 Views)
This KnowledgeBase appears to address the issue you are seeing. I found this by searching "error 32" at ni.com. Copying the contents of the second disk should fix this issue.
With warm regards,
David D.
(3,865 Views)
