Encoder position is not read/set correctly
Hi everyone,
I am currently  running into a problem I cant seam to fix.
To measure a linear position I use an encoder task. The task itselfe works well and counts the position as planned.
Still I am running into a major issue: For a new measurement I need to clear the buffer of the encoder task, because I dont want to get any old data. As just reading all the data out of the buffer (_encoderTask.Stream.ReadAllAvailableSamples = true; + _encoderTaskReader.ReadMultiSampleInt32(-1); )d oesnt do the job, there are still samples in the buffer.
So i followed this guide and tried to delete the task and create a new one for the new measurement. Now the problem is: if I read the current position from the encoder task, delete the task and create a new task with its startingposition to be the same as the last position of the old task, the positions dont match. I make an example to make this clear:
The task was running. Now I read the current position:
// Clear Buffer
// We need to start the clock task to get at least one sample
_clockTask.Start();
UInt32 pos = _encoderTaskReader.ReadSingleSampleUInt32();
_clockTask.Stop();
// Clear Buffer
I need to start the clock task for a very short amount of time, so a new sample is generated and I can read the current position.
Now that I have the current position (in Ticks) I reinit the encoder task:
_encoderTask.CIChannels.CreateLinearEncoderChannel(DeviceName + "/ctr0", "Encoder 1", CIEncoderDecodingType.X4, false, 0, CIEncoderZIndexPhase.AHighBHigh, 1, (double)pos/ 4, CILinearEncoderUnits.Ticks);
Funny thing here is: the read position gives you the position in ticks, but you need to devide this number by 4 to set the starting position, cause he doesn't accept the position in ticks but in "samples".
If i now read the position again:
// Clear Buffer
_clockTask.Start();
UInt32 pos2 = _encoderTaskReader.ReadSingleSampleUInt32();
_clockTask.Stop();
// Clear Buffer
pos and pos2 are not the same. The axis was not moving while this happens so there where no ticks generated (checked it with an osciliscope). The position is always 1-5 ticks smaller than the original one. As I generate new tasks every 5 seconds and have alot of measurements (several hundred), this errors sums up really quickly and ruins my measurements.
How do i fix this problem? Is there any way to reset the buffer of the task in another way? How do I initialize the task so the psotion doesn't differ?
Best,
nano
(5,799 Views)
Hello everyone,
this problem is still relevant and not solved.
Is there no one who can help me solve this? If so: where can I find someone able to determin the correct way to do this?
Best,
Nano
(5,717 Views)
I would try to cast the variable pos in this way:
((double)pos)/4.0
only 4 would cast the variable back to an integer and you will loose data.
kind regards
Richard
(5,606 Views)
