Drivers and other required for new application?
I am building a .NET application that will be installed onto a Windows 7 Embedded machine.  I will be using an Ethernet cDAQ 9184.  The chassis will have an NI 9205 module installed for sure, but possibly other different modules.  What software and drivers do I require to be installed on the Windows machine?  I have the NI Device Drivers disk (August 2015) but there are a lot of drivers on this disk and I want to be sure I'm installing only what I require.
(5,110 Views)
Hi DM@Means,
You definitely need to install the DAQmx driver. What other drivers come on the disk that you currently have?
Aaron F.
Applications Engineering
(5,084 Views)
There are 140 device drivers on this disk.
(5,078 Views)
For 9184 and 9205, you should only need NI-DAQmx. Make sure you select to install development support for the version of .NET Framework you will be using.
Daniel Dorroh
(5,073 Views)
Thanks for the feedback.  Will do.
(5,016 Views)
