Does the WaveFormGraph accept multithreading in c#
I m working on visual studio 2005 (in C#) and use WaveFormGraph component 8.5. My application is a MDI interface and each child window content a waveformgraph component. The problem appears when i create a child window, which embeded the component, from an external thread. I use delegates functions as it's explained by Microsoft, but it doesn't work fine. The error message says that the controls created on a thread can not be parents of a control of another thread (see the attached file).
Sometimes the child window is created correctly and sometime it is not. Is the WaveformGraph component thread safe ?
The line which cause the problem is :
                        try
                            myPhysGraphViewer.MdiParent = this;
                        catch(Exception Exc)
where :
 - 'this' is the instance of the main class
 - 'myPhysGraphViewer'  is the child window which contains the waveformgraph component
Could you help me please ?
Best regards
Norbert
(3,555 Views)
For each thread you can associate an interface with somes components.
Your problem it's that you want to acces to the component (created by a thread A) with an other thread B.
I invite you to read this tutorial about the multithreading :
Nacer M. | Certified LabVIEW Architecte
(3,531 Views)
